At this stage of my game I'm testing the functionality for my workflow, and I plan to put it into an Enterprise GDB environment. To answer your question, yes, those tables would have to be in the EGDB. That said, the trick is how to edit those non-versioned tables that exist in the EGDB environment, right? I think this explains it:
Configuring an ArcMap edit session to perform nonversioned edits—ArcGIS Help | ArcGIS for Desktop
Something I discovered in my test is the Attribute Assistant add in will not even turn if the DynamicValues table isn't present in your mxd. Something else worth noting is I recommend grabbing the Domains, especially those associated with the DymanicValues table from the original file geodatbase that ships with the local government information model download: use domain to table and then table to domain to get them into your database.
Paul Davidson
Joe, in a multi-user, multi-editting environment, shouldn't those tables be in an EGDB, at least if one is making use of the GenerateID table. Which the documentation says must not be versioned. And/or to share with others the various rules one sets up.
Depends of course a lot on how one's org & editing workflows are setup.
I'm using AA in my own mxd, outside of any ESRI templates or mxds:
Attribute Assistant | ArcGIS Solutions for the download
Just install it and add it as an add in with ArcCatalog. You need to add the tables that come with it to your mxd (At least the DynamicVlue table). Just create your own file Geodatabase and put your data and the AA tables there.
Is there an easy way to pull out the Attribute Assistant "code" from Infrastructure Network Editing and use it in other maps?
