InfoWindow window = new InfoWindow() { Anchor = e.MapPoint, Map = MyMap, IsOpen = true, ContentTemplate = LayoutRoot.Resources["LocationInfoWindowTemplate"] as System.Windows.DataTemplate, //Since a ContentTemplate is defined, Content will define the DataContext for the ContentTemplate Content = e.MapPoint };
I can't help you with the images, but in the sample for the InfoWindow the C# code behind handles that coordinate window like this:InfoWindow window = new InfoWindow() { Anchor = e.MapPoint, Map = MyMap, IsOpen = true, ContentTemplate = LayoutRoot.Resources["LocationInfoWindowTemplate"] as System.Windows.DataTemplate, //Since a ContentTemplate is defined, Content will define the DataContext for the ContentTemplate Content = e.MapPoint };The code for the original InfoWindow (for the feature layer) has a return when it's invoked, so this code only fires when you click outside the feature layer. It would probably be as simple as just removing this code as far as I can tell, or you could hook up an if (selection != null) to the original InfoWindow and leave the else unhandled.
Jonathan,Thanks! It really was that simple.Now to just figure out how to add images.Thanks,John
