Hi Mahalooutput results:0 = not visible 1= visible from one observer points 2 = visible from 2 observer points.3= (and so on....)I would also suggest to extract only values bigger then 0 with raster calculator using "CON" function, or use the model builder and with selection iterator to run the viewshed independently to each point and not to all of them together, in that way you will have the coverage of each point and you can merge the results later.
