I'm trying to run a query against portal to return all the registered users, but can't figure out how to get a wildcard variable to work.
This works:
<SPAN class="keyword token">let</SPAN> queryParameters <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN>
query<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"username:"</SPAN> <SPAN class="operator token">+</SPAN> portal<SPAN class="punctuation token">.</SPAN>user<SPAN class="punctuation token">.</SPAN>username
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN>
portal<SPAN class="punctuation token">.</SPAN><SPAN class="token function">queryUsers</SPAN><SPAN class="punctuation token">(</SPAN>queryParameters<SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>result<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>result<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>But I need to do something like this, which doesn't work:
query<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"username:*"</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Any ideas are much appreciated.
