gp = arcgisscripting.create(9.3) ... ... while sRow: pt = sRow.GetValue(shapeName).GetPart(0) ...
File "S:\scripts\test.py", line 91, in convertPointsToLinept = sRow.GetValue(shapeName).GetPart(0)AttributeError: 'NoneType' object has no attribute 'GetPart'
val = row.getValue(shapeField) if val: pt = val.getPart(0) else: pt = None
shapeField = desc.shapeFieldName sRow = arcpy.SearchCursor(fc) for row in sRow: pt = row.getValue(shapeField).getPart(0)
import arcgisscripting import os import types def convertPoints(inPts, outFeatures, IDField, cursorSort, close): gp = arcgisscripting.create(9.3) gp.OverWriteOutput = 1 # Input point FC # Output FC # Feature Field # Sort Field # Close Line or Leave Open # inPts = gp.GetParameterAsText(0) # outFeatures = gp.GetParameterAsText(1) # IDField = gp.GetParameterAsText(2) sortField = '#'#gp.GetParameterAsText(3) closeLine = "false"#gp.GetParameterAsText(4) if IDField in ["", "#"]: IDField = None if sortField in ["", "#"]: cursorSort = IDField else: if IDField: cursorSort = IDField + ";" + sortField else: cursorSort = sortField if types.TypeType(closeLine) != types.BooleanType: if closeLine.lower() == "false": close = False else: close = True convertPointsToLine(gp, inPts, outFeatures, IDField, cursorSort, close) def enableParam(hasMZ): if hasMZ: return "ENABLED" else: return "DISABLED" def convertPointsToLine(gp, inPts, outFeatures, IDField, cursorSort, close): #try: if 1 == 1: # Assign empty values to cursor and row objects iCur, sRow, sCur, feat = None, None, None, None desc = gp.Describe(inPts) shapeName = desc.ShapeFieldName # Create the output feature class # outPath, outFC = os.path.split(outFeatures) gp.CreateFeatureclass_management(outPath, outFC, "POLYLINE", "", enableParam(desc.hasM), enableParam(desc.hasZ), inPts) # If there is an IDField, add the equivalent to the output # if IDField: f = gp.ListFields(inPts, IDField)[0] tMap = {'Integer': 'LONG', 'String': 'TEXT', 'SmallInteger': 'SHORT'} fType = f.type if tMap.has_key(fType): fType = tMap[fType] fName = gp.ValidateFieldName(f.name, outPath) gp.AddField_management(outFeatures, fName, fType, f.precision, f.scale, f.length, f.aliasName, f.isNullable, f.required, f.domain) # Open an insert cursor for the new feature class # iCur = gp.InsertCursor(outFeatures) sCur = gp.SearchCursor(inPts, "", None, cursorSort, cursorSort) sRow = sCur.Next() # Create an array and point object needed to create features # array = gp.CreateObject("Array") pt = gp.CreateObject("Point") pt2 = gp.CreateObject("Point") # Initialize a variable for keeping track of a feature's ID. # ID = -1 while sRow: pt = sRow.GetValue(shapeName).GetPart(0) # If last point and this point are at identical locations # nudge it about 1.5 meters to make a line if pt2.X == pt.X and pt2.Y == pt.Y: pt.Y = pt.Y + 0.00001 pt.X = pt.X + 0.00001
gp = arcgisscripting.create()
Rewrite it using arcpy instead of arcgisscripting would be my suggestion. Have you tried creating the gp without forcing to 9.3?gp = arcgisscripting.create()A while ago a post here by Esri stated it would still be available in 10.1, so not sure what the issue is as I haven't dabble in 10.1 myself yet.http://forums.arcgis.com/threads/44713-Confirm-deprecation-of-arcgisscripting-at-10.1
Here is a useful blog post on updating arcgisscripting to arcpy:
https://gisstudio.wordpress.com/2011/12/30/things-to-keep-in-mind-when-switching-from-arcgisscripting-to-arcpy/
