I have published a service on my arcgis server 10.6. Next day when I come back I find the service to be missing.
The same has happened multiple times. Not able to find the cause for it.
Below are the logs for the same.
Feb 27, 2019, 7:59:23 AM
Error handling request to service 'xyz.MapServer'. java.lang.Exception: Could not find service. Service may be stopped or it may not be configured.
Soap
SEVERE
java.lang.Exception: java.lang.Exception: Could not find service. Service may be stopped or it may not be configured. at com.esri.arcgis.discovery.admin.rediscovery.actors.RediscoveryAppServer.handleRequest(RediscoveryAppServer.java:553) at com.esri.arcgis.discovery.wsh.ServiceHandlerServlet.service(ServiceHandlerServlet.java:306) at javax.servlet.http.HttpServlet.service(HttpServlet.java:742) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:231) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166) at org.apache.catalina.core.ApplicationDispatcher.invoke(ApplicationDispatcher.java:728) at org.apache.catalina.core.ApplicationDispatcher.processRequest(ApplicationDispatcher.java:470) at org.apache.catalina.core.ApplicationDispatcher.doForward(ApplicationDispatcher.java:356) at org.apache.catalina.core.ApplicationDispatcher.forward(ApplicationDispatcher.java:316) at com.esri.arcgis.discovery.wsh.DispatcherServlet.service(DispatcherServlet.java:181) at javax.servlet.http.HttpServlet.service(HttpServlet.java:742) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:231) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166) at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:199) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:96) at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:496) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:140) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:81) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:87) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:342) at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:803) at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:66) at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:790) at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1459) at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61) at java.lang.Thread.run(Thread.java:748) Caused by: java.lang.Exception: Could not find service. Service may be stopped or it may not be configured. at com.esri.arcgis.discovery.admin.rediscovery.actors.RediscoveryAppServer.handleRequest(RediscoveryAppServer.java:539) ... 31 more
Soap
SEVERE
Soap
SEVERE
Soap
WARNING
Feb 27, 2019, 7:53:53 AM
Unable to process request. Service xyz_SDE/MapServer not found
Rest
WARNING
Error getting service.
Rest
SEVERE
Error handling request to service 'xyz_SDE.MapServer'. The service 'xyz_SDE.MapServer' was not found. Verify the service exists and is started.
Soap
SEVERE
java.lang.Exception: The service 'xyz_SDE.MapServer' was not found. Verify the service exists and is started. at com.esri.arcgis.discovery.wsh.util.WSRequestUtil.getService(WSRequestUtil.java:357) at com.esri.arcgis.discovery.wsh.ServiceHandlerServlet.service(ServiceHandlerServlet.java:191) at javax.servlet.http.HttpServlet.service(HttpServlet.java:742) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:231) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166) at org.apache.catalina.core.ApplicationDispatcher.invoke(ApplicationDispatcher.java:728) at org.apache.catalina.core.ApplicationDispatcher.processRequest(ApplicationDispatcher.java:470) at org.apache.catalina.core.ApplicationDispatcher.doForward(ApplicationDispatcher.java:356) at org.apache.catalina.core.ApplicationDispatcher.forward(ApplicationDispatcher.java:316) at com.esri.arcgis.discovery.wsh.DispatcherServlet.service(DispatcherServlet.java:181) at javax.servlet.http.HttpServlet.service(HttpServlet.java:742) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:231) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166) at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:199) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:96) at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:496) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:140) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:81) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:87) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:342) at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:803) at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:66) at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:790) at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1459) at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61) at java.lang.Thread.run(Thread.java:748)
Soap
Any clue over this will be of great help.
Thanks in advance.
Kumar
