Hi Richard ??? thanks for your response. I think your solution would work if the text came from a single field. Unfortunately out text string is not retrieved from a single field (like [My_Field]), but built from many fields. We do it like this so we can control the colour of each character/symbol independently with tags around the field, e.g. FindLabel = "<CLR cyan='100'>" & [PoliceStation] & "</CLR>" & "<CLR magenta='100'>" & [CaravanPark] & "</CLR>"
Function FindLabel ( [PoliceStation], [CaravanPark], [Field3], [Field4], [Field5], [Field6], [Field7, [Field8]) ' etc. for all fields in your list myStr = "" myBreak = 6 i = 0 if [PoliceStation] > " " Then i = 1 myStr = "<CLR cyan='100'>" & [PoliceStation] & "</CLR>" End If if [CaravanPark] > " " Then ' This begins the basic block to copy if i = mybreak Then myStr = myStr & vbnewline i = 0 End If i = i + 1 myStr = myStr & <CLR magenta='100'>" & [CaravanPark] & "</CLR> End If ' This ends the basic block to copy if [Field3] > " " Then if i = mybreak Then myStr = myStr & vbnewline i = 0 End If i = i + 1 myStr = myStr & <CLR magenta='100'>" & [Field3] & "</CLR> End If if [Field4] > " " Then if i = mybreak Then myStr = myStr & vbnewline i = 0 End If i = i + 1 myStr = myStr & <CLR magenta='100'>" & [Field4] & "</CLR> End If if [Field5] > " " Then if i = mybreak Then myStr = myStr & vbnewline i = 0 End If i = i + 1 myStr = myStr & <CLR magenta='100'>" & [Field5] & "</CLR> End If if [Field6] > " " Then if i = mybreak Then myStr = myStr & vbnewline i = 0 End If i = i + 1 myStr = myStr & <CLR magenta='100'>" & [Field6] & "</CLR> End If if [Field7] > " " Then if i = mybreak Then myStr = myStr & vbnewline i = 0 End If i = i + 1 myStr = myStr & <CLR magenta='100'>" & [Field7] & "</CLR> End If if [Field8] > " " Then if i = mybreak Then myStr = myStr & vbnewline i = 0 End If i = i + 1 myStr = myStr & <CLR magenta='100'>" & [Field8] & "</CLR> End If 'etc. FindLabel = myStr End Function
We use a FindLabel expression to retrieve characters from a number of attribute fields (up to 32). The characters correspond to a font which display as symbols on the map, e.g. �??C�?� displays a Caravan Park symbol. The characters are concatenated into a single character string. There are no characters separating the symbols (e.g. a space). Where a feature has a lot of facilities (e.g. a major town), the resulting line of symbols can be rather long and look clumsy on the map.We would like to use an expression to force a line break after a given number of characters (e.g. 6), so that the symbols are stacked in a neat pile near the feature they describe. We have tried using the �??Stack Label�?� function in Maplex but have so far got inconsistent results.We�??d be grateful for any suggestions of a way to consistently force a line break after a specified number of characters.[ATTACH=CONFIG]13404[/ATTACH]
Function FindLabel ( [My_Field] ) myStr = "" myBreak = 6 For i = 1 to Int(Len( [My_Field] )/myBreak) if i = 1 Then myStr = Left( [My_Field], myBreak) End If myStr = mystr & vbNewLine & Mid([My_Field], i * myBreak + 1, myBreak) Next FindLabel = myStr End Function
