_measureAreaMouseMoveHandler : function (evt) { var _36; //after the first vertex is created... if (this.inputPoints.length > 0) { var _37 = new _15(this._map.spatialReference); var _38; //snap if snapping is enabled if (this._map.snappingManager) { _38 = this._map.snappingManager._snappingPoint; } _36 = _38 || evt.mapPoint; //add a path between the first vertex and where the mouse is hovering _37.addPath([this._currentStartPt, _36]); var _39 = this._densifyGeometry(_37); //add the geometry to the graphic this.tempGraphic.setGeometry(_39); } //after two verticies have been created... if (this.inputPoints.length > 1) { var _3a = new _15(this._map.spatialReference); //add a path back to the first point _3a.addPath([_36, this.inputPoints[0]]); var _3b = this._densifyGeometry(_3a); //add the geometry to the graphic this.tempGraphic.setGeometry(this.tempGraphic.geometry.addPath(_3b.paths[0])); } },
