I have manually added a toolbar to a document and created a number of macros in VBA which are run from the toolbar. These work perfectly in 9.3.1 however in 10, the buttons show [Missing ...] and of course no longer work.We have been told that the only solution is to re-write the Macros in VB.NET - which is in the plans - however my understanding was that 10 should run VBA, even if it no longer supported. I would appreciate it if someone could suggest what is the problem here.The extra VBA module has been installed with ArcMap 10 and a licence provided by ESRI is being used.
I haven't a clue what the underlying issue is.Since you stated that your need was "urgent" then a possible workaround might be for you to develop a non-VBA component to add to the toolbar which calls your VBA logic within it. Perhaps that will resolve the "urgent" problem until you can get an answer from ESRI support or another user.
