Hi I have an issue with the above tool. I am spatially relating many points to a line, the points (input features held in gdb) are arranged in a line parallel to and near to another line (near feature held in folder), I use the output table generated by the system. Both input features have the same geo co-ords and projections. If I select planar I get a set of results which fall within the range bounding the parallel lines. If I select Geodesic I get a set of results outside the parallel line extent. My projection is Mars2000_EquidistantCylindrical_CLON0 and the geographic co ord system, spherical. My problem extent ranges over a 10km square approx. and I am surprised that the geodesic results are so different, I suspect I should have done a reprojection ?,
I would appreciate any suggestions / advice please
