Ezequias,
I've converted the python scripts to auto synch on a schedule from the database server. That way, I don't have to worry about which version of the native client I have on the machine running the synchronization. Call me 'Garfield' or Lazy IT. I just don't want to experience these errors anymore. I've been running this from the Database server for over a year without complications. Try testing the synchronization from multiple native clients to see if you get the same response.
Luke
With the patch installed, you can use the 2012 Native Client again.-Shannon
http://support.esri.com/en/downloads/patches-servicepacks/view/productid/67/metaid/1954A patch was released in early February.-Shannon
I would have expected a patch by now.
The link doesn't work. It ask me to login and then takes me right back to the login page again.Seems to be some bugs in the website.
see http://support.esri.com/en/bugs/nimbus/role/beta10_1/TklNMDg3NzY1
I'm using the 2008 R2 client and still getting this message when trying to synchronize.All of this is so fragile, I'm a little worried to even think about using it with a client.
The nim NIM086855 is close to the earlier discussion/report on this synchronization issue.The workaround is listed as "Using SQL Server Native Client 2008 R2 for the ArcGIS Desktop machine to synchronize changes."Please contact Technical Support to confirm if this is the exact case encountered and/or regarding the workaround.Thank you,Mandar
Use SQL Native Client software at least as new as teh SQL Server database engine
I have seven deployments in which two are using replication. If this is a 2012 DB server issue, this needs to be fixed ASAP. All my new deployments are built on sql server 2012. It doesn't make sense to deploy on older versions.
just got off phone with with ESRI and no luck so far.For what its worth, when I run the synch tool from toolbox instead of the wizard tool bar i get the 'table already exists' in the results messages but also get a 'error 000582'.........which unfortunately is a catch-all type of error. Mandar, is there a bug reported? Because if not right now i'm not seeing any resolution or work around and if I understand what you're saying correctly if you have conflicts and if you have a 2012 DB server...you're outta luck? I'd suspect that there are a lot of people with this deployment scenario.
It seems that this issue is reproducible only with Sql Server 2012 and originates only when conflicts are present during the synchronization. Any successive synchronizations, even with new replica registered on this geodatabase, seem to encounter the "Table already Exists" error. The issue does not seem reproducible with other versions of Sql Server (for e.g. Sql Server 2008 R2.)- Mandar
