I am using print widget to print map, but receive this error "Uncaught TypeError: Converting circular structure to JSON"
Hi Wei,
I see this thread has been hanging out for a few months without a reply, so hopefully I'm not too late...
I recently encountered this myself and discovered a resolution. In my particular case, I had a dojox datagrid embedded within the mapping application. When the grid became populated with a data store, in this case:
var data = { identifier: "col_ID", //pk label: "col_label", //display field items: allItems }; //create data store and bind to grid store = new ItemFileReadStore({ data: data }); var grid = registry.byId("jGrid"); grid.setStore(store);
...the array allItems created a circular reference in the API print widget JavaScript during jsonification of the map. I resolved it, not so elegantly as it were, by performing a deep clone of the data store's items array. Here's the resolution for me:
//deep clone original items object var newArray = JSON.parse(JSON.stringify(allItems.slice())); var data = { identifier: "col_ID", //pk label: "col_label", //display field items: newArray }; //create data store and bind to grid. store = new ItemFileReadStore({ data: data }); var grid = registry.byId("jGrid"); grid.setStore(store);
Hope this helps!
