Thank your very much for your help. I'll try again with Zonal Toolset and maybe GME (http://www.spatialecology.com/gme/), successor of Hawth's Analysis Tools. If I find out something new, I'll let you know.
Yes, it's possible, but it won't give you more accurate result.Your result will be more precise but still will be as accurate as your least accurate data set.In other words, your result with decimals won't be closer to reality than result without decimals.
Is it possible maybe to convert raster to polygon and then with something else calculate intersection of two polygons with decimals, I mean real km2 values?
Your raster cell area is 1 km2, so the cell count is already an area in square kilometers.You will not get better precision that 1 km2 as raster cells are not clipped like polygons. Zonal tools take only whole cell and assign it to one of adjoining zones.
Hi!Thematic Raster Summary Tool (Hawth's Analysis Tools for ArcGIS) ... this tool only counts cells of each class inside polygon and fills attribute table with integer numbers.
