focusPoint:MapPoint (default = null) �?? The map point that should not move in relation to the screen.
<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx" xmlns:esri="http://www.esri.com/2008/ags"> <fx:Declarations> <esri:Extent id="initialExtent" xmin="-17731" ymin="6710077" xmax="-12495" ymax="6712279"> <esri:SpatialReference wkid="102100"/> </esri:Extent> </fx:Declarations> <fx:Script> <![CDATA[ import com.esri.ags.Graphic; import com.esri.ags.geometry.WebMercatorMapPoint; import com.esri.ags.symbols.SimpleMarkerSymbol; private function placePoint(evt:Event):void{ var wmp:WebMercatorMapPoint = new WebMercatorMapPoint(-0.088205,51.503306); var myGraphicMarker:Graphic = new Graphic(wmp, new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_DIAMOND, 22, 0x009933)); myGraphicsLayer.add(myGraphicMarker); //If you want the map to center at the point you created use the next line. myMap.centerAt(wmp); //Delay the map zoom by 1 second var timeoutExample:uint = setTimeout( function():void{ myMap.zoom(1 / 16, wmp); }, 1000 ); } ]]> </fx:Script> <esri:Map id = "myMap" extent="{initialExtent}" wrapAround180="false" x="52" y="209" width="383" height="221"> <esri:ArcGISTiledMapServiceLayer url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"/> <esri:GraphicsLayer id="myGraphicsLayer"/> </esri:Map> <s:Button click="placePoint(event)" label="test" /> </s:Application>
myMap.zoom(1/16, myGraphicMarker.geometry as WebMercatorMapPoint);
myMap.zoom(1 / 16, myGraphicMarker.geometry as MapPoint);
