In this example, the version of ArcGIS for Desktop is 10.1, which is the same version used for the exercises in this book. If you are using version 10.1 with a recent service pack, there should be no noticeable difference in how the Python code works. If you are using version 10.0, some of the Python code in the exercises will not work correctly because additional Python functionality has been introduced in 10.1.If you are using ArcGIS for Desktop 9.3.1 or earlier, the code in the exercises will not work. The ArcPy site package was introduced in version 10.0, and this includes Python functionality that was not available in earlier versions.
Hi Nidhin,You will be fine to use ArcGIS 10.2 with the ArcGIS 10.1 tutorial. With the exception of a few new Geoprocessing Tools, nothing has changed much from 10.1 to 10.2 in regards to Python.Jake
