var bbox = new esri.geometry.Extent({ "xmin": 175.0, "ymin": 15.0, "xmax": -175.0, "ymax": 25.0, "spatialReference": { "wkid": 4326 } });
Hello All,I'm using the web mercator projection and wrapAround180 option to provide seamless panning across the antimeridian. I would like to set the extent of the map to an area which in geographic coordinates would cross the antimeridian, e.g.var bbox = new esri.geometry.Extent(175.0,15.0,-175.0,25.0, new esri.SpatialReference({ wkid:4326 }));map.setExtent(esri.geometry.geographicToWebMercator(bbox),true);However this does not work, centering instead on central Africa and setting the zoom level to the maximum.Can someone please suggest the appropriate way to do this?Thanks!--john
//fake coords to avoid discontinuity - doesn't seem to help // var bbox = new esri.geometry.Extent({xmin:175.0,ymin:-5.0,xmax:185.0,ymax:5.0, spatialReference:{ wkid:4326 }}); var bbox = new esri.geometry.Extent({xmin:175.0,ymin:-5.0,xmax:-175.0,ymax:5.0, spatialReference:{ wkid:4326 }}); var merc = esri.geometry.geographicToWebMercator(bbox); esri.geometry.normalizeCentralMeridian([merc], 'http://maps.ngdc.noaa.gov/rest/services/Geometry/GeometryServer', function(geometries){ map.centerAndZoom(geometries[0],true); }, function() { console.log("error normalizing"); });
var bbox = new esri.geometry.Extent({xmin:175.0,ymin:-5.0,xmax:-175.0,ymax:5.0, spatialReference:{ wkid:4326 }}); esri.geometry.normalizeCentralMeridian([bbox], 'http://maps.ngdc.noaa.gov/rest/services/Geometry/GeometryServer', function(geometries){ var merc = esri.geometry.geographicToWebMercator(geometries[0]); map.centerAndZoom(merc,true); }, function() { console.log("error normalizing"); });
