<!doctype html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" /> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title>FeatureLayer On Demand</title> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.3/js/dojo/dijit/themes/claro/claro.css"> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } </style> <script type="text/javascript">djConfig = { parseOnLoad:true };</script> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.3"></script> <script type="text/javascript"> dojo.require("esri.map"); dojo.require("esri.layers.FeatureLayer"); var map; function init() { var extent = new esri.geometry.Extent({"xmin":-1091160.6279576253,"ymin":1464985.3783563056,"xmax":767849.8897356443,"ymax":2365380.130188807,"spatialReference":{"wkid":102039}}); map = new esri.Map("map", { extent: extent }); dojo.connect(map, "onLoad", initOperationalLayer); var base = new esri.layers.ArcGISDynamicMapServiceLayer("http://gis.apfo.usda.gov/ArcGIS/rest/services/CONUS/Overview/MapServer"); map.addLayer(base); } function initOperationalLayer(map) { var content = "<b>Abbr</b>: ${STATE_ABBR}<br /><b>FIPS</b>: ${STATE_FIPS}"; var infoTemplate = new esri.InfoTemplate("${STATE_NAME}", content); var featureLayer = new esri.layers.FeatureLayer("http://gis.apfo.usda.gov/ArcGIS/rest/services/CONUS/Overview/MapServer/1",{ mode: esri.layers.FeatureLayer.MODE_ONDEMAND, outFields: ["*"], infoTemplate: infoTemplate }); // explicitly set OID field as the layer being used // does not have it's OID field visible featureLayer.objectIdField = 'STATE_FIPS'; map.addLayer(featureLayer); map.infoWindow.resize(150,105); } dojo.ready(init); </script> </head> <body class="claro"> <div style="position:relative;width:100%;height:100%;"> <div id="map" style="border:1px solid #000;width:100%;height:100%;"> </div> </body> </html>
// use esri.request to get field info esri.request({ url: 'http://gis.apfo.usda.gov/ArcGIS/rest/services/CONUS/Overview/MapServer/1', content: { f: 'json' }, callbackParamName: 'callback', load: function(resp) { dojo.forEach(resp.fields, function(field) { console.log('field name is ', field.name, ' and field alias is ', field.alias); }); }, error: function(err) { console.log('err: ', err); } });
