ArcGISTiledMapServiceLayer layer = new ArcGISTiledMapServiceLaye("http://services.arcgisonline.com/ArcGIS/rest/services/Demographics/USA_Average_Household_Size/MapServer"); map.addLayer(layer);
mIdentifyTask = new IdentifyTask("http://services.arcgisonline.com/ArcGIS/rest/services/Demographics/USA_Average_Household_Size/MapServer");
When you are working with this sample there 3 changes necessary to make in order to make it work when you embed it in your application.1. Change the URLS = Which you have already done.2. you have to set the parameter layers through an Array. You have to specify which layer/layers of the map service you are accessing so change or alter this line "params.setLayers(new int[]{0});" in the curly braces change specify the layer/layer the tool has to access. for ed params.setLayers(new int[]{0,1,2,3});3. after accessing the layer you have to tell the tool on what bases or record it has to pull out. Usually it has to be a primary key like record_id or a object id so chanege the field name in the following code according to a primary key in your mapservice.in my case : if(curResult.getAttributes().containsKey("RECORDID")){ outputVal = curResult.getAttributes().get("RECORDID").toString(); With these three things done your code and tool should work fine.do reply as whether this worked.Regards,Nigel.
