Hi there folks, I created a Web App using the template builder from Portal for ArcGIS (10.7.1). The Web App was built using my Web Map that contained Arcade Expressions for aggregating information. However, within the Web App I am noticing the table results displaying a value of [objectPromise]. Why??? Attached is an example of what I'm seeing. Are Arcade Expressions not supported in Web Apps? Any help would be greatly appreciated.
Thank you
Jim Lugosi
Hi Ken, thanks for the response. Just found the documentation on the Version matrix. Guess we are using Arcade 1.7. It states that ArcGIS Runtime has no support for FeatureSet and this is a function I am using within my web map. The strange thing is that my web map is working just fine. The Arcade expression results are correct. It's just when I create a web app from the web map that the "objectPromise" starts showing up.
Remember that Portal is a few versions behind on Arcade implementation. Portal 10.7.1 uses Arcade 1.7. Are you using any functions that have been introduced in 1.8 or 1.9?
