I figured it out! If you lower-and-raise your screen resolution, the raster calculator expression box reappears! I went from 1920x1080 down to 1600x900 and it appeared, and when I went back to 1920x1080 it stayed there! I imagine I'll have to use this hack-solution every time I open arc, but I don't care! It worked for me!
Best Regards,Dylan
EDIT: EVEN SIMPLER SOLUTION!! (Found by Juan Carlos Villar Calle below, see link >> ArcToolbox - Missing box - YouTube
1. Open up the raster calculator window with the missing expression box)
2. Hold down crtl + scroll your mouse wheel up until it appears! (it must be some issue with the resolution of your screen and resolution of the box... I have no idea... but it works!
3. DONE!!!
Best Regards,
Dylan
import arcpy from arcpy.sa import * # myRas = arcpy.Raster('the name of the raster in the TOC or path to raster') myRas = arcpy.Raster('J000_CumCO2_kgha') # now you are able to perform any type of raster calculator analysis; like for instance: myResult = Con(IsNull(myRas),FocalStatistics(myRas,NbrRectangle(5,5,"CELL"),"MEAN","DATA"),myRas)
Hello XanderUsing Phyton may be a good idea to go around this problem, but the problem is I am a newone for Phyton. What I want to do is as the followings:1) use raster calcultor to evaluate "raster01 > 5000",2) in the resulting calculation layer (calc01), resympolize the "0" values to be "No Color" or transparent.I checked ArcGIS Desktop Help page and tried to use Phyton but might have some mistakes. Any help or suggestion will be welcomed.>>> import arcpy>>> from arcpy.sa import *>>> myRas = arcpy.Raster('raster01')>>> from arcpy import env>>> env.workspace="C:\GISdata\workspace">>> inRaster="raster01">>> "raster01>5000"'raster01>5000'>>> arcpy.CheckOutExtension("Spatial")u'CheckedOut'>>> Calcuation.save("C:\GISdata\workspace")Runtime error Traceback (most recent call last): File "<string>", line 1, in <module>NameError: name 'Calcuation' is not defined
import arcpy from arcpy import env env.workspace = r'C:\GISdata\workspace' # arcpy.CheckOutExtension("Spatial") myRas = arcpy.Raster('raster01') myResult = myRas > 5000 myResult.save('myOutputName')
This actually worked for me too! Big thanks for the post!
Try this, I think it's just a window size problem. ArcToolbox - Missing box - YouTube
