How I work with WFS layers with Arcgis API for javascript 4.*?
I view this link but it is for arcgis api for javascript 3.*
WFS Layer | ArcGIS API for JavaScript 3.25
Thanks.
If you check the compatibility matrix WFS is still marked as coming soon.
Thanks for response. How can I solve this problem without waiting for a new version to be released? Is there a workaround?
There is no workaround that I am aware of.
Two years later from the original post, I have the same question. Is there a way to use WFS in the Javascript API ?
Thank you!
Two and a half years later from the original post, I have the same question. Is there a way to use WFS in the Javascript API 4.x?
Hello, They do not support WFS, but they support the new feature service of the OGC standards, OGC API Features:
https://developers.arcgis.com/javascript/latest/api-reference/esri-layers-OGCFeatureLayer.html
It basically works the same way as WFS.
Hope this helps!
Hi, so is it possible to load regular WFS services with the OGCFeatureLayer class?
What I am trying to do is load a WFS such as this one with API 4. I did not manage to set the parameters right to make it work.
I did not find a working example with a generic WFS service, but a post with the same issue.
Hi! I actually replied by accident with my organisation account (AdministrationOGSL), but I am actually the same person. So the issue you shared was actually posted by me. The thing is that the OGCFeatureLayer class of ArcGIS uses the OGC API - Features, and not WFS. The OGC API - Features is a service to access features, but that is newer than WFS.So to use it, this service (OGC API-Features) has to be added to the capabilities of the geoserver that you use. If it is the geoserver of your organisation, this can be easily done (https://docs.geoserver.org/latest/en/user/community/ogc-api/index.html ). If not, I think your best bet would be tu use another module to create your map (such as OpenLayers).Hope this helps!
