Hi Erik,
Where you able to accomplish this? I'm having the same problem. Where did you create the parser to reference to only one map (div).
Hi Eric,I highly recommend reading the starter tutorials for the ESRI JSAPI. Even though you are using a storymaps template, you really do need to know javascript basics before coding with our library. Concerning your issue: it looks like the majority of your application logic exists in main.js, which you did not post. I assume the map object is defined in main.js, which would most likely be out of scope if you were trying to access it from your main html. You also override any preexisting context by using "var map" at the beginning of your require block. The starter tutorials address things like this. If you don't know much about scope and context, I also suggest reading up on those concepts. Hope this helps!
Hi Eric,Tough to say, but I don't see the map constructor in the code you posted. There is: "var map;" and "map: map" only.I would compare what you have to the basemap gallery sample and look for differences.Hope this helps!-Noah
<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Edit rivers and waterbodies</title> <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/esri/css/esri.css" /> <link rel="stylesheet" href="http://code.jquery.com/mobile/1.3.0/jquery.mobile-1.3.0.min.css" /> <style> html, body { height: 100%; margin: 0px; overflow:hidden; padding: 0px; width: 100%; } #map { height: 100%; width: 100%; overflow:hidden; position: absolute; z-index: 0; } #draggable{ display: inline-block; position:absolute; float:left; width:10px; height:10px; left:10px; top:360px; z-index:50px; padding: 0.5em; } #HomeButton { position: absolute; top: 245px; left: 20px; z-index: 10; } #LocateButton { position: absolute; top: 280px; left: 20px; z-index: 50; } h1{ text-align: center; } #login { height: 100%; width: 100%; position: absolute; z-index: 0; overflow:hidden; background-color:black; color:white; } #container { position: fixed; width: 340px; height: 280px; top: 50%; left: 50%; margin-top: -140px; margin-left: -170px; } .templatePicker { border: none; } </style> <script src="http://code.jquery.com/jquery-1.9.0.min.js"></script> <script src="http://code.jquery.com/mobile/1.3.0/jquery.mobile-1.3.0.min.js"></script> <script src="http://js.arcgis.com/3.9/"></script> <script> var sh = true; var map; function showUser(str, pass) { if (str=="") { document.getElementById("txtHint").innerHTML=""; return; } if (window.XMLHttpRequest) { // code for IE7+, Firefox, Chrome, Opera, Safari xmlhttp=new XMLHttpRequest(); } else { // code for IE6, IE5 xmlhttp=new ActiveXObject("Microsoft.XMLHTTP"); } xmlhttp.onreadystatechange=function() { if (xmlhttp.readyState==4 && xmlhttp.status==200) { if(xmlhttp.responseText == 'ADMIN') { document.getElementById('login').style.display = "none"; document.getElementById('draggable').style.display = "none"; require([ "esri/map", "esri/tasks/GeometryService", "esri/toolbars/edit", "esri/dijit/HomeButton", "esri/dijit/BasemapGallery", "esri/dijit/LocateButton", "esri/layers/ArcGISDynamicMapServiceLayer", "esri/layers/FeatureLayer", "esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol", "esri/dijit/editing/Editor", "esri/dijit/editing/TemplatePicker", "esri/config", "dojo/i18n!esri/nls/jsapi", "dojo/_base/array", "dojo/parser", "dojo/keys", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!" ], function( Map, GeometryService, Edit, HomeButton, BasemapGallery, LocateButton, ArcGISDynamicMapServiceLayer, FeatureLayer, SimpleMarkerSymbol, SimpleLineSymbol, Editor, TemplatePicker, esriConfig, jsapiBundle, arrayUtils, parser, keys ) { parser.parse(); //This service is for development and testing purposes only. We recommend that you create your own geometry service for use within your applications. esriConfig.defaults.geometryService = new GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer"); map = new Map("map", { basemap: "osm", center: [-98.185272, 26.282376], logo: false, sliderStyle: 'large', zoom: 9, }); var home = new HomeButton({ map: map }, "HomeButton"); home.startup(); geoLocate = new LocateButton({ map: map }, "LocateButton"); geoLocate.startup(); var basemapGallery = new BasemapGallery({ showArcGISBasemaps: true, map: map }, "basemapGallery"); basemapGallery.startup(); basemapGallery.on("error", function(msg) { console.log("basemap gallery error: ", msg); }); map.on("layers-add-result", initEditor); //add boundaries and place names var dynamic = new ArcGISDynamicMapServiceLayer("http://maps.lrgvdc911.org:6080/arcgis/rest/services/STEAR/STEAR_DYNAMIC/MapServer"); map.addLayer(dynamic); var events = new FeatureLayer("http://maps.lrgvdc911.org:6080/arcgis/rest/services/Public_Outreach/EVENTS/FeatureServer/0",{ mode: FeatureLayer.MODE_ONDEMAND, outFields: ['*'] }); map.addLayers([events]); function initEditor(evt) { var templateLayers = arrayUtils.map(evt.layers, function(result){ return result.layer; }); var templatePicker = new TemplatePicker({ featureLayers: templateLayers, grouping: true, rows: "auto", columns: 1 }, "draggable"); templatePicker.startup(); var layers = arrayUtils.map(evt.layers, function(result) { return { featureLayer: result.layer }; }); var settings = { map: map, templatePicker: templatePicker, layerInfos: layers, toolbarVisible: true, createOptions: { polylineDrawTools:[ Editor.CREATE_TOOL_FREEHAND_POLYLINE ], polygonDrawTools: [ Editor.CREATE_TOOL_FREEHAND_POLYGON, Editor.CREATE_TOOL_CIRCLE, Editor.CREATE_TOOL_TRIANGLE, Editor.CREATE_TOOL_RECTANGLE ] }, toolbarOptions: { reshapeVisible: true } }; var params = {settings: settings}; var myEditor = new Editor(params,'editorDiv'); //define snapping options var symbol = new SimpleMarkerSymbol( SimpleMarkerSymbol.STYLE_CROSS, 15, new SimpleLineSymbol( SimpleLineSymbol.STYLE_SOLID, new Color([255, 0, 0, 0.5]), 5 ), null ); map.enableSnapping({ snapPointSymbol: symbol, tolerance: 20, snapKey: keys.ALT }); myEditor.startup(); } }); } else { alert(xmlhttp.responseText); } } } xmlhttp.open("GET",'testinfo.php?u='+str+'&p='+pass,true); xmlhttp.send(); } function hide() { if(sh) { sh = false; document.getElementById('draggable').style.display = "none"; } else { sh = true; document.getElementById('draggable').style.display = "block"; } } </script> </head> <body class="claro"> <div data-theme="a" data-role="header" data-position="fixed"> <h3>LRG Kidz</h3> <a href="#featureDialog" data-role="button" class="ui-btn-right" onclick="hide();">Hide</a> </div> <div id="map"> <div id="HomeButton"></div> <div id="LocateButton"></div> <div style="position:absolute; right:20px; top:10px; z-Index:999;"> <div data-dojo-type="dijit/TitlePane" data-dojo-props="title:'Switch Basemap', closable:false, open:false"> <div data-dojo-type="dijit/layout/ContentPane" style="width:380px; height:280px; overflow:auto;"> <div id="basemapGallery" ></div> </div> </div> </div> </div> <div id="draggable"></div> <div id="login"> <h1>Welcome</h1> <div id="container"> <form> <label for="username">Username:</label> <input type="text" id="username" name="username"> <label for="password">Password:</label> <input type="password" id="password" name="password"> <div id="lower"> <input type="button" value="Login" onclick="showUser(username.value, password.value);"/> </div><!--/ lower--> </form> </div> </div> </body> </html>
