...huge non-existing polygon around...
I had the same problem. Finally I could identify the/one reason.I had one big polygon around the area to be digitized (here: the watershed boundary). Inside I wanted to digitize a hydro-geological map and use the watershed boundary as outer boundary applying the "auto complete polygon" tool. This did not work, neither completing polygons to the outer boundary nor to any other polygon.After I deleted the outer boundary from the attribute table, the auto complete polygon tool worked fine for completing adjacent polygons.
I am digitising a map in ArcMap 10.0 SP 2 with a few hundred polygons. I use auto complete polygons to avoid drawing all the lines twice. I use it using both straight segment and trace (along another layer) to draw the lines.Most polygons end up right, but some aren't created when I finish drawing. Also when trying again and making sure to go from existing polygons' vertices or crossing polygons' boundaries the polygon won't draw. A workaround I found is drawing the polygon in parts. But still, one part may draw and the other may not. I then draw even smaller parts and smaller parts until it works. Eventually I fill the polygon with smaller parts (sometimes 2, sometimes 20) and merge them, but it is costing me a lot of time circumventing around unwanted and strange ArcMap behaviour.I looked up various other posts and errors about auto-complete. The main one if found was about the polygon drawn not being complete visible, but I tried zooming out until I saw the polygon drawn and all the adjacent polygons in full and it still wouldn't draw. Also some polygons will draw regardless of zoomlevel.Anyone encounter this before and found a (better) way to deal with it?
