'pSR is a variable containing a spatial reference 'in this case, I'm creating an in-memory point feature class pFeatureClass = CreateInMemoryFeatureClass2("temporary", ESRI.ArcGIS.Geometry.esriGeometryType.esriGeometryPoint, pSR) Public Function CreateInMemoryFeatureClass2(ByVal Name As String, InShapeType As ESRI.ArcGIS.Geometry.esriGeometryType, InSR As ESRI.ArcGIS.Geometry.ISpatialReference3) As ESRI.ArcGIS.Geodatabase.IFeatureClass Dim CreateFC As New ESRI.ArcGIS.DataManagementTools.CreateFeatureclass Dim ShapeType As String Dim Result As ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2 Try Using releaser As New ESRI.ArcGIS.ADF.ComReleaser releaser.ManageLifetime(CreateFC) Select Case InShapeType Case ESRI.ArcGIS.Geometry.esriGeometryType.esriGeometryPoint ShapeType = "Point" Case ESRI.ArcGIS.Geometry.esriGeometryType.esriGeometryPolyline ShapeType = "Line" Case ESRI.ArcGIS.Geometry.esriGeometryType.esriGeometryPolygon ShapeType = "Polygon" Case Else Return Nothing End Select CreateFC.out_path = "in_memory" CreateFC.out_name = Name CreateFC.geometry_type = ShapeType CreateFC.spatial_reference = InSR Result = RunTool(CreateFC, Nothing) If Result Is Nothing Then System.Windows.Forms.MessageBox.Show("Could not create InMemory dataset") Return Nothing End If Return ReturnObjectfromResult(Result, "Feature Class") End Using Catch ex As Exception System.Windows.Forms.MessageBox.Show(ex.ToString, "Create InMemory Featureclass error") Return Nothing End Try End Function Friend Function ReturnObjectfromResult(ByVal result As ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2, ByVal Type As String) As Object Dim GPVal As ESRI.ArcGIS.Geodatabase.IGPValue Dim InMemFC As String Dim GPUtil As ESRI.ArcGIS.Geoprocessing.IGPUtilities3 = New ESRI.ArcGIS.Geoprocessing.GPUtilities Try GPVal = result.GetOutput(0) InMemFC = GPVal.GetAsText() Select Case Type Case "Feature Class" Return GPUtil.OpenFeatureClassFromString(InMemFC) Case "Table" Return GPUtil.OpenTableFromString(InMemFC) End Select Catch ex As Exception System.Windows.Forms.MessageBox.Show(ex.ToString, "Return FeatureClass error") Return Nothing End Try End Function Friend Function RunTool(ByVal Process As ESRI.ArcGIS.Geoprocessor.IGPProcess, ByVal TC As ESRI.ArcGIS.esriSystem.ITrackCancel2) As ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2 Dim Result As ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2 Dim GP As New ESRI.ArcGIS.Geoprocessor.Geoprocessor Try Result = CType(GP.Execute(Process, Nothing), ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2) If Result.Status <> ESRI.ArcGIS.esriSystem.esriJobStatus.esriJobSucceeded Then ReturnMessages(Result, "Geoprocessing Error") Catch ex As Exception System.Windows.Forms.MessageBox.Show(ex.ToString, "Run Geoprocessor") End Try Return Result End Function Private Sub ReturnMessages(ByVal pResult As ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2, ByVal Title As String) Dim ErrorMessage As String If pResult.MessageCount > 0 Then For Count As Integer = 0 To pResult.MessageCount - 1 ErrorMessage += pResult.GetMessage(Count) Next End If System.Windows.Forms.MessageBox.Show(ErrorMessage, Title) End Sub
