I need assistance writing a conditional statement that says if the dataset is already Unregistered to skip the balance and go directly to comp = arcpy.Compress_management(editDB)
Thank You in advance........Larry Adgate
import arcpy
editDB = "Database Connections\\Arden@gsw_sde.sde"
workspace = editDB
arcpy.env.workspace = workspace
#Need a conditonal Statment: if dataset is already UnregisterAsVersioned to go directly to comp
datasets = arcpy.ListDatasets("*", "Feature")
print datasets
for dataset in datasets:
fcList = arcpy.ListFeatureClasses("*","",dataset)
for fc in fcList:
print fc
arcpy.UnregisterAsVersioned_management(fc,"NO_KEEP_EDIT","COMPRESS_DEFAULT")
#if already Unregistered, skip the balance and go to below:
for fc in fcList:
arcpy.RegisterAsVersioned_management(fc, "NO_EDITS_TO_BASE")
