So it appears that my while loop isn't looping.
InputRasters = gp.ListRasters() ## InputRasters.reset() NOT NECESSARY, the enumeration is new ## InputRaster = InputRasters.next() # DELETE - this skips to the second record
What parameters must I input in the parameters tab to get this to work? I am new to scripts and getting them to work.
# BatchZonalStatisticsAsTable.py # Description: Summarizes values of a raster within the zones of another dataset and reports the results to a table # Requirements: None # Author: David Coley # Date: 05/10/06 #import win32com.client, sys, os, string import arcgisscripting gp = arcgisscripting.create() gp.CheckOutExtension("Spatial") gp.CellSize = 1 #can set as argument gp.OverWriteOutput = 1 try: gp.Workspace = "C:\\working\\Temp\\testing\\grids" InZonalLayer = "C:\\working\\Temp\\testing\\TreatmentFranksTract2010.mdb\\Controls" InZonalValueField = "PIN" #can set as argumment #set output workspace which holds tables in a gdb OutWorkSpace = "C:\\working\\Temp\\testing\\outputs3" #Get the raster datasets in the input workspace and loop through them from the start InputRasters = gp.ListRasters() InputRasters.reset() InputRaster = InputRasters.next() OutTable = "C:\\working\\Temp\\testing\\outputs3\\" + InputRaster + "_stats.dbf" while InputRaster: # Process: Zonal Statistics as Table gp.ZonalStatisticsAsTable_sa(InZonalLayer, InZonalValueField, InputRaster, OutTable, "DATA") # print InputRaster InputRaster = InputRasters.next() #print OutTable except: gp.AddMessage(gp.GetMessages(2)) print gp.GetMessages(2)
This looks promising, but I'm still on 9.3I'll be trying to get this to work, but could use help if anyone feels like translating this.
All, Here's a follow up. With help from Luke I managed to get a crude script for 10. It looks like this:import arcpy from arcpy import env env.workspace = "C:\Path" outfile = open("C:\RastStats.txt", 'w') PropTypes = ["MINIMUM", "MAXIMUM", "MEAN"] rastlist = arcpy.ListRasters("*", "") for raster in rastlist: rastname = str(raster) outfile.write(rastname + "\n") for PropType in PropTypes: print PropType Prop = arcpy.GetRasterProperties_management(raster, PropType) textinfo = (PropType, Prop) textstring = str(textinfo) outfile.write(textstring + "\n") outfile.close()
# GetRasterProperties.py # Description: Write raster properties to a file. # Note: Written for ArcGIS 9.3. # Create the Geoprocessor object import arcgisscripting gp = arcgisscripting.create() # Get input parameters InRaster = gp.GetParameterAsText(0) OutFile = gp.GetParameterAsText(1) #Property Types PropertyTypes=['MINIMUM','MAXIMUM','MEAN','STD','UNIQUEVALUECOUNT','TOP','LEFT','RIGHT','BOTTOM','CELLSIZEX','CELLSIZEY','VALUETYPE','COLUMNCOUNT','ROWCOUNT','BANDCOUNT'] #Output file OutFile=open(OutFile,'w') # Process: GetRasterProperties for PropertyType in PropertyTypes: try: Property = gp.GetRasterProperties(InRaster, PropertyType) gp.AddMessage('%s=%s'%(PropertyType,Property)) OutFile.write('%s=%s\n'%(PropertyType,Property)) except: # Print error message if an error occurs gp.AddMessage(gp.GetMessages(2)) OutFile.close()
