<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Select with feature layer</title> <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/dojo/dijit/themes/tundra/tundra.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/esri/css/esri.css"> <style> html, body, #mapDiv { padding: 0; margin: 0; height: 100%; } #messages{ background-color: #fff; box-shadow: 0 0 5px #888; font-size: 1.1em; max-width: 15em; padding: 0.5em; position: absolute; right: 20px; top: 20px; z-index: 40; } </style> <script src="http://js.arcgis.com/3.9/"></script> <script> var map; require([ "esri/map", "esri/layers/FeatureLayer", "dijit/form/ToggleButton", "esri/tasks/query", "esri/geometry/Circle", "esri/graphic", "esri/InfoTemplate", "esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol", "esri/symbols/SimpleFillSymbol", "esri/renderers/SimpleRenderer", "esri/config", "esri/Color", "dojo/parser", "dojo/dom", "dojo/on", "dojo/domReady!" ], function( Map, FeatureLayer, ToggleButton, Query, Circle, Graphic, InfoTemplate, SimpleMarkerSymbol, SimpleLineSymbol, SimpleFillSymbol, SimpleRenderer, esriConfig, Color, parser, dom, on ) { esriConfig.defaults.io.proxyUrl = "/proxy"; parser.parse(); map = new Map("mapDiv", { basemap: "streets", center: [-95.249, 38.954], zoom: 14, slider: false }); //add the census block points in on demand mode. Note that an info template has been defined so when //selected features are clicked a popup window will appear displaying the content defined in the info template. var featureLayer = new FeatureLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/0",{ infoTemplate: new InfoTemplate("Block: ${BLOCK}", "${*}"), outFields: ["POP2000","HOUSEHOLDS","HSE_UNITS", "TRACT", "BLOCK"] }); // selection symbol used to draw the selected census block points within the buffer polygon var symbol = new SimpleMarkerSymbol( SimpleMarkerSymbol.STYLE_CIRCLE, 12, new SimpleLineSymbol( SimpleLineSymbol.STYLE_NULL, new Color([247, 34, 101, 0.9]), 1 ), new Color([207, 34, 171, 0.5]) ); featureLayer.setSelectionSymbol(symbol); //make unselected features invisible var nullSymbol = new SimpleMarkerSymbol().setSize(0); featureLayer.setRenderer(new SimpleRenderer(nullSymbol)); map.addLayer(featureLayer); var circleSymb = new SimpleFillSymbol( SimpleFillSymbol.STYLE_NULL, new SimpleLineSymbol( SimpleLineSymbol.STYLE_SHORTDASHDOTDOT, new Color([105, 105, 105]), 2 ), new Color([255, 255, 0, 0.25]) ); var circle; new ToggleButton({ showLabel: true, onChange: function(val){ if(val == true){ buffer = map.on("click", function(evt){ circle = new Circle({ center: evt.mapPoint, geodesic: true, radius: 1, radiusUnit: "esriMiles" }); map.graphics.clear(); map.infoWindow.hide(); var graphic = new Graphic(circle, circleSymb); map.graphics.add(graphic); var query = new Query(); query.geometry = circle.getExtent(); //use a fast bounding box query. will only go to the server if bounding box is outside of the visible map featureLayer.queryFeatures(query, selectInBuffer); }); this.set('label', 'Clear Buffer'); } else{ map.graphics.clear(); featureLayer.clearSelection(); buffer.remove(); this.set('label', 'Create Buffer'); } }, label: "Create Buffer" }, "buffer"); function selectInBuffer(response){ var feature; var features = response.features; var inBuffer = []; //filter out features that are not actually in buffer, since we got all points in the buffer's bounding box for (var i = 0; i < features.length; i++) { feature = features; if(circle.contains(feature.geometry)){ inBuffer.push(feature.attributes[featureLayer.objectIdField]); } } var query = new Query(); query.objectIds = inBuffer; //use a fast objectIds selection query (should not need to go to the server) featureLayer.selectFeatures(query, FeatureLayer.SELECTION_NEW, function(results){ var totalPopulation = sumPopulation(results); var r = ""; r = "<b>The total Census Block population within the buffer is <i>" + totalPopulation + "</i>.</b>"; dom.byId("messages").innerHTML = r; }); } function sumPopulation(features) { var popTotal = 0; for (var x = 0; x < features.length; x++) { popTotal = popTotal + features.attributes["POP2000"]; } return popTotal; } }); </script> </head> <body> <span id="messages">Click on the map to select census block points within 1 mile.</span> <div id="mapDiv"> <button id="buffer"></button> </div> </body> </html>
function toggleLayer (layerId) { var layer = map.getLayer(layerId); if (layer.visible){ layer.setVisibility(false); }else{ layer.setVisibility(true); } }
Here is an example you can build off of:http://jsfiddle.net/UjK29/
Here is a helpful link about creating a widget:https://developers.arcgis.com/javascript/jstutorials/intro_custom_dijit.html
