if arcpy.Exists("in_memory\\matchtable"): arcpy.Delete_management("in_memory\\matchtable") ## setup for the attachments input = r"H:\Documents\ArcGIS\Default.gdb\InstantValues" inputField = "InstantValues_staname" matchTable = arcpy.CreateTable_management("in_memory", "matchtable") matchField = "STATION" pathField = "Picture" arcpy.AddField_management(matchTable, matchField, "TEXT") arcpy.AddField_management(matchTable, pathField, "TEXT") picFolder = str(outfolder) ## check to see if matchtable exists and remove attachements if it does fields = ["STATION", "Picture"] cursor = arcpy.da.InsertCursor(matchTable, fields) ##go thru the picFolder of .png images to attach for file in os.listdir(picFolder): if str(file).find(".png") > -1: pos = int(str(file).find(".")) newfile = str(file)[0:pos] cursor.insertRow((newfile, file)) del cursor # the input feature class must first be GDB attachments enabled arcpy.EnableAttachments_management(input) # use the match table with the Add Attachments tool arcpy.AddAttachments_management(input, inputField, matchTable, matchField, pathField, picFolder) arcpy.AddMessage("Attachments enabled/created")
# Made your in memory table and add pertinent data table = arcpy.CreateTable_management("in_memory", tableName) arcpy.AddField_management(table, "ID", "LONG", 9) arcpy.AddField_management(table, "NAME", "TEXT") # Insert your data fields = ["ID","NAME"] with arcpy.da.InsertCursor(table,fields) as insertcursor: for row in dataToInsert: insertcursor.insertRow(row) # Some tools may require a table view ... arcpy.MakeTableView_management(table, "table_view") # Make sure to clean up your workspace, especially for larger batch processes arcpy.Delete_management(table) arcpy.Delete_management("table_view")
