Its just a personal preference I guess. As long as it is functional.
to be short, it looks like it was designed by marketing, not a developer. Fine for the examples, not fine for an API
Dojo 1.7 (the version of Dojo used by version 3.0 of the ArcGIS API for JavaScript) fully supports creating classes and modules using Asynchronous Module Definition (AMD) style code while continuing to support the older, dojo.declare style of module and custom class creation
Yes thats it. Its just a frustration with the way the web is going.Desktop screens are getting more and more landscape. Content is getting more and more portrait. It just doesn't work together.
My take is that the web is mimicking print more and more. As our displays become more capable (hi-def, retina, blah blah blah), content on the web can be presented the way content is presented in print. I personally like this trend. Take these two presentations of the same article:http://bits.blogs.nytimes.com/2013/02/01/the-origins-of-big-data-an-etymological-detective-story/?hphttp://bits.blogs.nytimes.com/2013/02/01/the-origins-of-big-data-an-etymological-detective-story/?hp&pagewanted=printWhich do you like better? Even with the ads and additional junk, I prefer the first. The second, while it uses nearly all available space is harder to read because it is so wide.
If I might make several suggestions:1) it would help me if I could resized the left panel to either make it bigger or smaller so that I have more "usable" area in the content section
2) It would be extremely helpful if ESRI could provided an object model for the Javascript API. Having the text is great, but a picture/model can say a hundred words (or whatever the adage is ). Sometimes I feel like I am navigating all over the place to find the objects that I need .. a model would help tremendously.
3) Please update the samples to include the AMD style of coding. <snip>
To conclude, it seems like ESRI has already improved the Help site since it first came out and I have confidence that it will get better - Design. We appreciate your quick response. I do not feel like it is as cumbresome (since the fixes) but I do agree that there is a lot of wasted space (it's all personal preferences, right).
the new site here is more like the second, just with a narrower width.
It is the ads and "additional junk" that is the value add that feels like its missing. Maybe not.
FAir enough. As a developer, i am used to (and prefer) api's to look like thishttp://docs.oracle.com/javase/6/docs/api/the value add is in the linking. Note every inch of the screen has value in some form.
I tried using the "SeatGeek" sample that you have and it did not work correctly - the sample is referencing an older version of the JavascriptAPI and when you plug in the 3.3 version it does not work.
We haven't had an Object Model Diagram (OMD) for the API since 2009. We'll look into publishing one again.
We didn't quite go full Zeldman for the site but I'd be lying if I said we weren't at least a little influenced by design elements from the A List Apart crowd.
Developers and data managers may visit the site on a daily basis to find important data and information to help them get along with their latest project. They aren't so much interested in "Communities", as each project they do may actually be in an entirely different "Community"... such is developer work... they simply want the quickest access to API, Help, whitepapers, technical papers there is to solve urgent issues they have and find out how to do things. And in terms of "Communities", the only thing they are probably really interested in, is the Forum pages, to get direct help of peers...One example that could use improvement, is the link to the API (Help) references that is "hidden" under the "Help" menu option in the ArcGIS Resources section (http://resources.arcgis.com/en/home/), while I think many developers would prefer a separate direct API's menu option in the same main menu. This would also cut back on the great amount of links under the "Help" section.The same link to the API's list could be under the important:http://support.esri.com/en/page, which already gives direct access to many important things for developers and GIS geodatabase administrators.I think separating out the "Developer Help" from the other help sections ("ArcGIS Help", "Application Help" etc.), and giving a more prominent position to the API references with all the object models, interfaces etc, via a direct link in the main menu's of the Support and Resources pages would at least be one change of use to many. I also think "API (References)" is a better name for this than "Developer Help", as most developers are more used to that first term when searching for details on object models, classes, methods and interfaces.
For what it's worth*, I'd argue that the two sites have very different purposes - ALA is optimised for reading articles, whereas the Esri site needs to be aimed at providing information.But thanks for responding and making the recent changes, which are definitely making a difference.
Derek,Do you happen to know when the Javascript team is going to fix the mobile samples? Everyone of the mobile samples error in IE 8.Thanks.brian
In the future, please start a new thread instead of piggybacking on an existing, unrelated thread.
That being said, we'll take a look at the mobile samples in IE8. Realistically, those are meant for browsers running on phones/tablets, not legacy browsers.
Sorry about that but I've contacted support multiple times and cannot get a straight answer. There is also a bug submitted, but of course, that is set to low priority.
Yes, you are correct but if you wanted to create a adaptive web page (to work on both platforms), instead of having 2 separate code bases, you would want the application to also work in IE 8. Our IE 7/8 usage is still 20% of all hits. Not something we can ignore.
