Thank you for the information. I think the network do matters. I have seen some limitations when you load the map without network.
However, I tested your scenario with Airplane mode on with the following code and it works.
mMapView.addLayer(new ArcGISLocalTiledLayer(Environment.getExternalStorageDirectory().getPath()+"/ArcGIS/SanFrancisco.tpk"),0);
and activity_main.xml should be:
<!-- MapView -->
<com.esri.android.map.MapView
android:id="@+id/map"
android:layout_width="fill_parent"
android:layout_height="fill_parent">
</com.esri.android.map.MapView>
Is there anything different with your code?
Thank you all for your responses, I was seeing the issue again yesterday using 10.2.5. I do not use the network for my maps, I have cached maps for offline use.
Sample of how I add a map:
currentMapLayer = new ArcGISLocalTiledLayer("/sdcard/" + filename + ".tpk");
mapView.addLayer(currentMapLayer);
Thanks again for the help.
I can not reproduce this issue with 10.2.4 and 10.2.5. Would you like to provide more information about the settings? How is your network settings?
I haven't come across this problem myself using 10.2.4. Might be beneficial to show how the layer is being created.
Thank you for the response Dan, this does still happen in v10.2.4. I have not had the opportunity to upgrade to 10.2.5 yet. Have you seen this before or are you aware of it?
Thanks.
Does it still occur in v10.2.4 or v10.2.5?
I am still looking for an answer to this issue. Has anyone see this before or have an advice?
Thank you.
Has anyone seen this before? Any help please?
