but use a UniqueValueDefinition instead
Are you sure you want to try to show hundreds of different colors on a map?
Features all render the same color at some threshold of unique value quantities.
<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9"> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title>Unique Value Renderer</title> <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.2/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.2/js/esri/css/esri.css"> <script>var dojoConfig = { parseOnLoad: true };</script> <script src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.2"></script> <script> dojo.require("esri.map"); dojo.require("esri.layers.FeatureLayer"); var map; dojo.ready(function() { var bounds = new esri.geometry.Extent({"xmin":-14558502,"ymin":2799695,"xmax":-6731350,"ymax":6713271,"spatialReference":{"wkid":102100}}); map = new esri.Map("map", { extent: bounds, slider: false }); map.addLayer(new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer")); var defaultSymbol = new esri.symbol.SimpleFillSymbol().setStyle("none"); defaultSymbol.outline.setStyle("none"); // query for attribute values then find uniques var layerUrl = "http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StateCityHighway_USA/MapServer/1"; var field = "SUB_REGION"; var qt = new esri.tasks.QueryTask(layerUrl); var q = new esri.tasks.Query(); q.returnGeometry = false; q.outFields = [ field ]; q.where = "1=1"; var result = qt.execute(q); result.then(function(response) { var uniques = []; dojo.forEach(response.features, function(f) { if ( dojo.indexOf(uniques, f.attributes[field]) === -1 ) { uniques.push(f.attributes[field]); } }); // generate a color ramp var ramp = createRamp(uniques.length); //create renderer var renderer = new esri.renderer.UniqueValueRenderer(defaultSymbol, field); // add values to the renderer with symbols using colors from the color ramp dojo.forEach(ramp, function(c, idx) { var symbol = new esri.symbol.SimpleFillSymbol().setColor(new dojo.Color(c)); // symbol.outline.setColor(c); renderer.addValue(uniques[idx], symbol) }); // create the feature layer var featureLayer = new esri.layers.FeatureLayer(layerUrl, { mode: esri.layers.FeatureLayer.MODE_ONDEMAND, outFields: [ field ] }); featureLayer.setRenderer(renderer); // finally, add the layer to the map map.addLayer(featureLayer); console.log("added feature layer"); }, function(err) { console.log("query task to get attributes failed"); }); function createRamp(count) { var index = 0; var factor = parseInt(360/count); var colors = []; while ( index < count ) { var hue = index * factor colors.push(color_from_hue(hue)); index += 1; } return colors; } // source: http://rainbowcoding.com/how-to-create-rainbow-text-in-html-css-javascript/ function color_from_hue(hue) { var h = hue/60; var c = 255; var x = (1 - Math.abs(h%2 - 1))*255; var color; var i = Math.floor(h); if (i == 0) color = rgb_to_hex(c, x, 0); else if (i == 1) color = rgb_to_hex(x, c, 0); else if (i == 2) color = rgb_to_hex(0, c, x); else if (i == 3) color = rgb_to_hex(0, x, c); else if (i == 4) color = rgb_to_hex(x, 0, c); else color = rgb_to_hex(c, 0, x); return color; } function rgb_to_hex(red, green, blue) { var h = ((red << 16) | (green << 8) | (blue)).toString(16); // add the beginning zeros while (h.length < 6) h = '0' + h; return '#' + h; } // end functions from rainbowcoding.com }); </script> </head> <body> <div id="map" class="claro" style="width:800px; height:400px; border:1px solid #000;"></div> </body> </html>
