When you use the Load data within the Geodatabase and when you get the Error Message, Where does it save the file to ? It gave you all the OID and the Error description that I need to investigate the errors.
Thanks !
I'm using ArcGIS 10.3.1
Thanks for that respond. I don't recalled checking on that one. I don't think it would have show up there, does it ?
Because when I did that simple load data and got the error it did not say it would show up there...
The next time if I do the same thing, I would be checking on it.
Did you try searching through the Geoprocessing > Result window?
My experience has been if you find one, you typically find them all; that is, more often than not if you are getting hundreds, it's the same error for all of them. You might take a look at append instead of the simple data loader, it may make finding the errors easier.
I could have done that as well but what if you have 100's ?? There must be a way around to do that. I hope someone else can answer to my question.
I've wondered that myself. My suggestion is to copy the errors (hold left mouse click, 'smear') and paste them into a text file.
