I am using ExportToPDF in a Python script. With none of the optional parameters set, the export works great. Now I want to define some parameters to tweak the PDF file size and such. I am finding that some of the values for the 'image_compression' parameter are not available; namely JPEG and ADAPTIVE. These parameter values are not available in the Python Window in ArcGIS, and if defined in a Python script, throw errors when the script is run. I have attached a screenshot showing the available values for the 'image_compression' parameter in the Python Window in ArcGIS. Also, note in the attached screenshot that the 'jpeg_compression_quality' parameter is not even an option. Can anybody shed light on why these parameters are in the documentation but are not accessible from the Python Window or when running a Python script? Thanks in advance, Brad
