Hi All,I am going to be working with point data that is sensitive and cannot be in a published map service, not even with tokens. I want to do a spatial selection on the points to select the points within a polygon and return attribute information only. First, is it possible to do a spatial selection against data that is not published as a map service? I could choose to store the data in any of these formats that might work -(feature class, could be in file gdb, sde, layer in mxd, or even flat sql table). Second, is there any example of this? I looked at this tutorial (http://help.arcgis.com/en/arcgisserver/10.0/help/arcgis_server_dotnet_help/index.html#/GP_service_example_Selecting_data/00930000003w000000/) and at #2 "Geoprocessing Service with Source Map Document" it seems to indicate that a geoprocessing service can access datasets on a disk.My fallback idea is to run a straight sql query on the data and loop through each coordinate to check if it's inside or outside a polygon, but that will only be if I can't find a better way. Thanks,Chuck
