This has been a complaint for years, and ESRI more or less finally listened by providing the Geodatabase Administration dialogs and tools at 10.1, and, as you already understood, by making "Direct Connect" default as of 10.1, which takes away the burden of getting your ArcSDE Application Server service running.On the other hand, I do think to many organizations take the geodatabase administrator role to lightly, often, the role is often historically just fulfilled by anyone who happens to know "a little more" than the rest. In the land of the blind, the one eyed man is king...I am not suggesting this applies to you, just in general. To be a really good geodatabase administrator, you need to be both versed in DBA work, and know the GIS side of it all. That may require professional training through ESRI courses.I think this Help page will help you out on the answer of your question (scroll down to "Options" - yes, it is a keyword) and any others you might have:The sdeservice commandhttp://resources.arcgis.com/en/help/install-guides/arcsde-application-server-microsoft-sql-server/10.1/index.html#//00950000004m000000As the above help page says, the "-r" determines which Windows registry key you are going to set. The "-v" is where you put the actual value that the registry key should take on, in your case the name of the DBA user.E.g., in your case, if you have DBO schema, the commands are probably going to look something like this. Replace everything starting with "Your" by values based on your instance. "YourDBOLoginName" is the name of the login associated with your DBO user in your SQL server instance:sdeservice -o create -d SQLSERVER,YourSQLServerInstanceName -p YourDBOpassword -i esri_sdesdeservice -o register -r SDE_DBA_USER -v YourDBOLoginName -i esri_sde -p YourDBOpassword -d SQLSERVER,YourSQLServerInstanceNamesdeservice -o register -r ADMIN_DATABASE -v YourDatabaseName -i esri_sde -p YourDBOpassword -d SQLSERVER,YourSQLServerInstanceNameYou may need to use "-o modify" instead of "-o register" since you already made an attempt at setting these registry keys.
This was finally the trick - I didn't realize that the -r -v combos were actually the type of thing being modified and then the actual entry. I couldn't make sense of that in the instructions anywhere. So once we figured out that you could only run one combo of -r and -v that did the trick, but we had to do both, one for the database name, another for the User. Thanks.
Why would a software vendor not make this easier. Oh, so dummies can't muck it up? Or so the administrators can't get the systems to work?
"4. If you are using a dbo-schema geodatabase, type the sdeservice command with the register operation to register the user with which the giomgr will connect to the database.sdeservice -o register -d SQLSERVER,MYSERVER\SSINSTANCE-r SDE_DBA_USER -v esri_sde -i esri_sde"What is not clear is a) if SDE_DBA_USER is a specific username or is this some kind of keyword? Or you're supposed to put in an actual user name how do you do it. I tried mine and it wouldn't accept it.
None of the examples seem to address how to create ArcSDE services on DBO schema. What are the real parameters? I've edited the sdeservices.sde file and the windows services file. I'm using a custom named service. It creates the service but it won't start.This is such an archaic system. Why not a GUI? I know you don't want us to use services anymore but I've got a bunch of things created that use them and I want to upgrade the geodb's and SDE to 10.1. I've got 10.1 of ArcGIS, ArcGIS server, ArcGIS SDE, Windows 2008 R2, SQL Server 2008 R2, on a test server.I tried doing:sdeservice -o create sqlserver,servername -i service_nameIt created something but still wouldn't start.sdeservice -o register -d sqlserver,servername -r SDE_DBA_USER -v service_name -i service_nameIt registered something but the service still won't create. Is SDE_DBA_USER something real? Should I put something else there? I tried using my DBO login but no dice. Desperate.
