for fc in fclist: arcpy.selectLayerByLocation_management(highway,"Have_their_center_in", fc) arcpy.GetValue(STFID from the current fc table) arcpy.UpdateCursor(STFID for selected roads in roads table)
import arcpy #Set geoprocessing environment arcpy.env.workspace = r"I:\Dr. Hines\New File Geodatabase.gdb" arcpy.env.overwriteOutput = True #Create list of all blocks fcList = arcpy.ListFeatureClasses("*blk00") highway = "Analysis Roads" #Create loop for fc in fcList: arcpy.SelectLayerByLocation_management(highway,"HAVE_THEIR_CENTER_IN", fc) rows = arcpy.UpdateCursor(highway) for row in rows: row.STFID = fc.STFID rows.updateRow(row) del row del rows
for fc in fcList: X = arcpy.SelectLayerByLocation_management("Analysis Roads","HAVE_THEIR_CENTER_IN", fc) highway = X #I think you want highway to = X which is the selection of analysis roads from the previous #operation? rows = arcpy.UpdateCursor(highway) for row in rows: if row is in X:#I dont think this is correct if statement... should be something like if X==ROW row.STFID = fc.STFID rows.updateRow(row) del row #these del row, del rows should be tabbed outside of the loop, not inside del rows
>>> import arcpy >>> #Set geoprocessing environment >>> arcpy.env.workspace = r"I:\Dr. Hines\New File Geodatabase.gdb" >>> arcpy.env.overwriteOutput = True >>> #Create list of all blocks >>> fcList = arcpy.ListFeatureClasses("*blk00") >>> #Create loop >>> for fc in fcList: ... X = arcpy.SelectLayerByLocation_management("Analysis Roads","HAVE_THEIR_CENTER_IN", fc) ... highway = "Analysis Roads" ... rows = arcpy.UpdateCursor(highway) ... for row in rows: ... if row is in X: ... row.STFID = fc.STFID ... rows.updateRow(row) ... del row ... del rows
import arcpy #Set geoprocessing environment arcpy.env.workspace = r"H:\Dr. Hines\New File Geodatabase.gdb" # \ is an escape character in python strings and needs the raw flag or to be doubled to act as a character arcpy.env.overwriteOutput = True #Create list of all blocks fcList = arcpy.ListFeatureClasses("*blk00") #Create loop for fc in fcList: blk = fcLis # Looks like a misspelling. Shouldn't this be fcList arcpy.SelectLayerByLocation_management("Analysis Roads","HAVE_THEIR_CENTER_IN") for fc in fcList: # this is bad. Never loop the same object within a loop of itself. Create a new list object to loop if you need an embedded loop. rows = arcpy.InsertCursor(blk) row = rows.newRow() row.STFID = () fieldVal = row.getValue("STFID") arcpy.CalculateField_management("Analysis Roads","STFID","fieldVal")
import arcpy #Set geoprocessing environment arcpy.env.workspace = "H:\Dr. Hines\New File Geodatabase.gdb" arcpy.env.overwriteOutput = True #Create list of all blocks fcList = arcpy.ListFeatureClasses("*blk00") #Create loop for fc in fcList: selected = arcpy.SelectLayerByLocation_management("Analysis Roads","HAVE_THEIR_CENTER_IN", fc) highway = "Analysis Roads" rows = arcpy.UpdateCursor(higway) for row in rows: if row is in selected: row.STFID = fc.STFID #this is assuming your feature classes have a STFID field too, you can change this to the right field name. rows.updateRow(row)
import arcpy #Set geoprocessing environment arcpy.env.workspace = "H:\Dr. Hines\New File Geodatabase.gdb" arcpy.env.overwriteOutput = True #Create list of all blocks fcList = arcpy.ListFeatureClasses("*blk00") #Create loop for fc in fcList: blk = fcLis arcpy.SelectLayerByLocation_management("Analysis Roads","HAVE_THEIR_CENTER_IN") for fc in fcList: rows = arcpy.InsertCursor(blk) row = rows.newRow() row.STFID = () fieldVal = row.getValue("STFID") arcpy.CalculateField_management("Analysis Roads","STFID","fieldVal")
You can wrap a code block in code tags when you place it in the message window It makes it easier to read
