If you use sharing folder with GDB inside, you need on server to change sharing security for user which connects to this folder. If you not have user in this section like in image below, you can add this by click edit then click add to append your user with full control permission. OK
bumped into this on 10.2 and Shelby's solution fixed the issue.
lauramendenhall6:Was the operating system where you had Arc 10.1 installed different from the operating system where you had Arc 10.0 installed?I have found that a Windows Server 2008 machine has higher security settings where, even though I am a local admin on the machine, I still need to explicitly tell the machine that I want to run software As Administrator in order for the software to work properly.
