Dave - The fastest and easiest way to populate your subtype field is use "Select by Attributes" and select the records based on a particular attribute value. For example, Type = "Interstate". From there, use the Field Calculator and calculate the subtype field to the appropriate subtype code (i.e. Subtype_Field = 1) Do this workflow for the remaining 14 subtype codes. There are other ways to select features as well - manual approach and then use the Field Calculator.Hope this helps!Robert LeClairEsri-Denver
Hi Karl,
Did you get help for this issue?
How did you select subtype field in field calculator anyway?
Thanks.
Any updates on this one? I stumbled upon it today...
I am having this same issue... I would like to apply default values to a large set of records based on subtype but I cannot figure out how to do this other than manually calculating fields or selecting subtype from drop down on one record at a time.
I find that when I use Field Calculator to calculate the subtype field, it doesn't update the other fields with the associated default values for that subtype. Only when I manually select a subtype value (from the drop-down list) for a particular row, do the other fields update.
Is there a way to update the subtype of multiple features in one go, which also updates the other fields to their defaults for that subtype?
