<?xml version="1.0" encoding="utf-8"?> <mx:TitleWindow xmlns="assets.*" xmlns:mx="http://www.adobe.com/2006/mxml" xmlns:esri="http://www.esri.com/2008/ags" xmlns:samples="com.esri.ags.samples.*" width="320" height="400" paddingLeft="10" paddingRight="10" paddingTop="10" paddingBottom="10" x="0" y="82" title="Table of Contents" dropShadowEnabled="true" dropShadowColor="Black" shadowDirection="right" shadowDistance="5" showCloseButton="true"> <mx:Script> <![CDATA[ import com.esri.ags.layers.ArcGISDynamicMapServiceLayer; import mx.controls.Alert; import com.esri.ags.samples.LayerTOC; import com.esri.ags.samples.LayerVizRenderer; import com.esri.ags.layers.Layer; import com.esri.ags.Map; [Bindable] public var layers:ArcGISDynamicMapServiceLayer; private var _layer:Layer; //set layer alpha private function setLayerAlpha():void { layers.alpha = slider.value; } private function sldrDataTipFormatter(value:Number):String { return int(value * 100) + "%"; } ]]> </mx:Script> <mx:VBox verticalGap="0" width="100%" paddingLeft="6" paddingRight="6" paddingBottom="3" paddingTop="3"> <mx:HSlider id="slider" minimum="0" maximum="1" width="100%" change="setLayerAlpha()" dataTipFormatFunction="sldrDataTipFormatter" liveDragging="true" value="{layers.alpha}"/> </mx:VBox> <samples:LayerTOC id="toc" layer="{layers}" width="280"/> </mx:TitleWindow>
<?xml version="1.0" encoding="utf-8"?> <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" xmlns:esri="http://www.esri.com/2008/ags" xmlns:samples="com.*" xmlns:local="*" layout="absolute"> <mx:Script> <![CDATA[ import mx.effects.Move; import mx.managers.PopUpManager; import flash.events.Event; private var dragPanel:TOCPanel; private function showDragWindow():void { //optional display effect var move : Move = new Move; move.xTo = 100; move.yTo = 150; if (dragPanel == null) { dragPanel = TOCPanel( PopUpManager.createPopUp(this, TOCPanel, false) ); //listen for close event if youve enabled close button dragPanel.layers = myDynamicService; dragPanel.addEventListener( "close", dragPanel_close ); PopUpManager.centerPopUp( dragPanel ); move.play( [dragPanel] ); } else { PopUpManager.addPopUp(dragPanel,this,false); dragPanel.layers = myDynamicService; dragPanel.visible = true; move.play( [dragPanel] ); } } private function dragPanel_close(evt:Event):void { PopUpManager.removePopUp(dragPanel); } ]]> </mx:Script> <esri:Map> <esri:ArcGISDynamicMapServiceLayer id="myDynamicService" url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/{myURL.selectedItem}/MapServer" load="myDynamicService.defaultVisibleLayers(); showDragWindow();"/> </esri:Map> <mx:ComboBox id="myURL" selectedIndex="0" horizontalCenter="0"> <mx:Array> <mx:String>Demographics/ESRI_Census_USA</mx:String> <mx:String>Demographics/ESRI_Population_World</mx:String> <mx:String>Specialty/ESRI_StateCityHighway_USA</mx:String> <mx:String>Specialty/ESRI_StatesCitiesRivers_USA</mx:String> <mx:String>Specialty/SuperTuesdaySample</mx:String> <mx:String>Louisville/LOJIC_LandRecords_Louisville</mx:String> <mx:String>Louisville/LOJIC_PublicSafety_Louisville</mx:String> </mx:Array> </mx:ComboBox> <mx:Button click="showDragWindow()" label="Show TOC" left="60" /> </mx:Application>
<?xml version="1.0" encoding="utf-8"?> <mx:TitleWindow xmlns="assets.*" xmlns:mx="http://www.adobe.com/2006/mxml" xmlns:esri="http://www.esri.com/2008/ags" xmlns:samples="com.esri.ags.samples.*" width="320" height="400" paddingLeft="10" paddingRight="10" paddingTop="10" paddingBottom="10" x="0" y="82" title="Table of Contents" dropShadowEnabled="true" dropShadowColor="Black" shadowDirection="right" shadowDistance="5" showCloseButton="true"> <mx:Script> <![CDATA[ import com.esri.ags.layers.ArcGISDynamicMapServiceLayer; import mx.controls.Alert; import com.esri.ags.samples.LayerTOC; import com.esri.ags.samples.LayerVizRenderer; [Bindable] public var layers:ArcGISDynamicMapServiceLayer; ]]> </mx:Script> <samples:LayerTOC id="toc" layer="{layers}" width="280"/> </mx:TitleWindow>
