An ArcGIS Server 10 layer can include a Renderer in the Drawing Info.e.g. http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Earthquakes/EarthquakesFromLastSevenDays/MapServer/0The Flex API's FeatureLayer will use this by default. If you're using a layer that does not have any Drawing Info, then the default symbology is used. You can set a renderer or symbol on the FeatureLayer since these properties are inherited from GraphicsLayer:http://help.arcgis.com/en/webapi/flex/apiref/com/esri/ags/layers/GraphicsLayer.html
1. Open a web browser and type in the address http://yourarcgisservername/arcgis/rest/ and then go to the map service in question click on the link for "ArcGIS JavaScript" and see if the symbology is correct there.
2. For the querying part ensure that you shape and id fields are not hidden in the map services MXD.
Is your ArcGIS Server version 10? Using a FeatureLayer, you can only get symbology back from AGS10. I had this issue when I started using FeatureLayer's before I upgraded my server.
Does your symbology is part of a graphic layer or is it part of a base map?If a basemap as a wrong symbology, then I believe it is a problem with the rest service itself. Maybe you can check the appearance of the images that are queried to the server with a tool like firebug.
