I am testing to use Kendo-UI into WAB. The home.html attached is a sample code for autocomplete and also I downloaded the trial version of Kendo-UI Jquery in my "useJquery" folder. I am using the sample Widget "UseJquery" template as two attachments. Based on the following link " jQuery loader accepts a second argument of an array of pulgins to load along with jQuery", to load two .js libs in my code.
jquery - How to load JQueryUI into Web AppBuilder? - Geographic Information Systems Stack Exchange
I am not able to get the reference "styles/kendo.default-v2.min.css" to work. Also, I am not sure the two js files referenced correctly or not.
Please give your thoughts on this.
Tom
To have references in index.html at the root folder, I am able to make this Kendo AutoComplete works.
But I need to implement the references js and CSS inside the "useJquery" folder, any help???
