I have a stream service published from GeoEvent Server ( 10.7) to our Portal. Is there a way to publish the service to an Enterprise AGOL account other than adding it as an item in AGO?
Hi Sowjanya Sunkara,
if you publish a Stream Layer to your ArcGIS Enterprise you also just add a item to your ArcGIS Enterprise Portal.
The Stream Layer itself will be hosted on the ArcGIS Server part of the GeoEvent Server with a underlying WebSocket that is hosted on the GeoEvent Server.
So I would say right now it is not possible to publish a Stream Layer in ArcGIS Online.
ArcGIS Analytics for IoT will bring real-time capability to ArcGIS Online, so let's see what will be possible in the future.
Best Stefan
Stefan P. Jung Thanks for clarifying. I can still add the stream layer ( hosted on the ArcGIS Sever) as an item to ArcGIS Online and should be able to see content?
