<xsl:template match="Field[FieldName = 'Original WO' or FieldName = 'Last WO']"> <xsl:choose> <xsl:when test="number(FieldValue) = FieldValue and number(FieldValue) != 0"> <tr> <th>Original WO DWG (if exists)</th> <!-- This is what I'm telling it to display for the field name if it meets the above criteria --> <td><a target="_blank"> <xsl:attribute name="href">file:\\Engineering\Drawings\Const Drawings\<xsl:value-of select="FieldValue"/>.dwg</xsl:attribute> <xsl:value-of select="FieldValue"/> </a> </td> </tr> <tr> <!-- Here is the second entry, just another table row --> <th>As-Built PDF (if exists)</th> <td><a target="_blank"> <xsl:attribute name="href">file:\\Engineering\Drawings\Const Drawings\ASBUILTS\<xsl:value-of select="FieldValue"/>.pdf</xsl:attribute> <xsl:value-of select="FieldValue"/> </a> </td> </tr> </xsl:when> <xsl:otherwise> <!-- If the field name matches, but the field value isn't a number, it displays things like normal. Just one table row, unmodified name & value --> <tr> <th><xsl:value-of select="FieldName"/></th> <!-- This line is an example of how the field name is displayed normally --> <td><xsl:value-of select="FieldValue"/></td> </tr> </xsl:otherwise> </xsl:choose> </xsl:template>
