Trying to map some addresses using the Customer Setup dialog and get this error:There is a known issue when using Address Coder with the Business Analyst 2013 dataset. The Business Analyst team is working on fixing this issue as quickly as possible.If you have access to the USA_ESRI_2012 dataset and switch BA to it then Address Coder will function as normal.Address Coder will now close.Any idea when this will be fixed?
