Dim pFlayer As ESRI.ArcGIS.Carto.IFeatureLayer Dim pFlayer1 As ESRI.ArcGIS.Carto.IFeatureLayer pFlayer = pMxDoc.FocusMap.Layer(1) pFlayer1 = pMxDoc.FocusMap.Layer(0) SelectbyLocation(pFlayer, pFlayer1, "INTERSECT", "NEW_SELECTION") Friend Sub SelectbyLocation(ByVal InputLayer As ESRI.ArcGIS.Carto.IFeatureLayer2, ByVal SelectionLayer As ESRI.ArcGIS.Carto.IFeatureLayer2, ByVal OverlapType As String, ByVal SelectionType As String) Dim SelByLoc As New ESRI.ArcGIS.DataManagementTools.SelectLayerByLocation Dim Result As ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2 Try Using releaser As New ESRI.ArcGIS.ADF.ComReleaser releaser.ManageLifetime(SelByLoc) SelByLoc.in_layer = InputLayer SelByLoc.overlap_type = OverlapType SelByLoc.select_features = SelectionLayer SelByLoc.selection_type = SelectionType Result = RunTool(SelByLoc, Nothing) If Result Is Nothing Then System.Windows.Forms.MessageBox.Show("Could not select features") End If End Using Catch ex As Exception System.Windows.Forms.MessageBox.Show(ex.ToString, "Select Layer by Location") End Try End Sub Private Sub ReturnMessages(ByVal pResult As ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2, ByVal Title As String) Dim ErrorMessage As String If pResult.MessageCount > 0 Then For Count As Integer = 0 To pResult.MessageCount - 1 ErrorMessage += pResult.GetMessage(Count) Next End If System.Windows.Forms.MessageBox.Show(ErrorMessage, Title) End Sub Friend Function RunTool(ByVal Process As ESRI.ArcGIS.Geoprocessor.IGPProcess, ByVal TC As ESRI.ArcGIS.esriSystem.ITrackCancel2) As ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2 Dim Result As ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2 Dim GP As New ESRI.ArcGIS.Geoprocessor.Geoprocessor Try Result = CType(GP.Execute(Process, Nothing), ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2) If Result.Status <> ESRI.ArcGIS.esriSystem.esriJobStatus.esriJobSucceeded Then ReturnMessages(Result, "Geoprocessing Error") GP.ClearMessages() Catch ex As Exception ReturnMessages(Result, "Fail") System.Windows.Forms.MessageBox.Show(ex.ToString, "Run Geoprocessor") End Try Return Result End Function
