Hi csa aus,
I tried importing the certificate (pfx with all certs) via IIS and via certmgr.msc. Both appeared to work.
I do not see the certificate I want to use under: http://server:6080/arcgis/admin/machines/Server.Domain.LOCAL/sslcertificates
When I try to importRootOrItermediate via http://server:6080/arcgis/admin/machines/Server.Domain.LOCAL/sslcertificates/importRootOrIntermediate
I continue to get 'Importing CA Certificate Failed'.
In my case we have a wildcard certificate *.extdomain.com which is for a different domain than the local GIS server. I want to use it to expose the rest services to the outside world. e.g.
Using http://abc.extdomain.com/arcgis/rest/services works internally
We need to use: https://abc.extdomain.com/arcgis/rest/services in the outside world.
Can you clarify anything that might help?
Thank you, Marcel
