wukong sun, What is the geo object? If it is a MapPoint than it's extent is null.
QiTian,I think your question is to ask how to create a default extent of the map. Usually, the mouseclick event not control the extent of the map. Like you said, the map extent is usually set with a static value by using Xmin, Ymin, Xmax, Ymax.I suggest you to read this link might helpful to you to understand the extent in Flex API:https://developers.arcgis.com/en/flex/guide/using-extent.htmlAlso, this link provide you the com.esri.ags property, it includes how to use extent syntax https://developers.arcgis.com/en/flex/api-reference/com/esri/ags/Map.html#extentHope this can help you.
var extent:Extent = geometry.extent; // returns null for MapPoint or Multipoint's with only one point if (extent) { map.zoomTo(geometry); } else { var mapPoint:MapPoint; if (geometry is MapPoint) { mapPoint = geometry as MapPoint; } else if (geometry is Multipoint) { var multipoint:Multipoint = geometry as Multipoint; if (multipoint.points && multipoint.points.length > 0) { mapPoint = multipoint.points[0]; } } if (mapPoint) { // make sure the infoWindow always points to the current (selected) feature map.infoWindow.show(mapPoint); // Zoom to 1/16th the size of the current extent. // This is the same as calling map.zoomIn() four times. map.zoom(1 / 16, mapPoint); if (!map.extent.contains(mapPoint)) { map.centerAt(mapPoint); } } }
Wukong Sun, Here is how you handle it (taken your esri code in popuprendereskin): var extent:Extent = geometry.extent; // returns null for MapPoint or Multipoint's with only one point if (extent) { map.zoomTo(geometry); } else { var mapPoint:MapPoint; if (geometry is MapPoint) { mapPoint = geometry as MapPoint; } else if (geometry is Multipoint) { var multipoint:Multipoint = geometry as Multipoint; if (multipoint.points && multipoint.points.length > 0) { mapPoint = multipoint.points[0]; } } if (mapPoint) { // make sure the infoWindow always points to the current (selected) feature map.infoWindow.show(mapPoint); // Zoom to 1/16th the size of the current extent. // This is the same as calling map.zoomIn() four times. map.zoom(1 / 16, mapPoint); if (!map.extent.contains(mapPoint)) { map.centerAt(mapPoint); } } }
map.extent = map.initialExtent; var resultlist:Array=new Array(); for each(var griphic:Graphic in featureSet.features) { var geo:Geometry= griphic.geometry; var pnt :MapPoint = geo as MapPoint ; map.centerAt(pnt); map.extent = map.extent.expand(0.2); break; }
map.scale = 2400;
