I use directionsLanguage get router infomation, By default, NAServer gets installed with en_US only , how to add additional languages?
Are you using the Directions Widget? If so try setting the directionsLanguage. See this post for details: Re: changing default instruction text in directions widget
I use RouteTask.Set the routeParams directionsLanguage option in order to display the output directions in a particular language.
routeParams.directionsLanguage= "vi";
my code is not working!!
It looks like Vietnamese is not one of the supported languages. See the directionsLanguage section of this help topic.
im do the same things as you write m but it is not working , is there configuration for the service
