New to GIS and learning online with Coursera. I am not able to find my scratch.gdb. I downloaded the zip file and all and I don't see it in any of the files there. Only results.gdb and source.gdb.
Did not know that...i am running out of hands.
Another face to palm tip if you don't already know it...for network drives with connections, you can add the path and not have all the drives mapped to a letter. I find this handy since I tend to run out of A-Z.
This makes it so much easier to navigate to common work folders esp in a network environment...seems obvious but i didn't start doing this until about 2-3 years into my career.
Face meet Palm.
Just to make sure you are not actually looking for the results.gdb and source.gdb .... for those, you will need to map to the drive (of you can do the folder) that the .gdb are located using the + icon
Then you should be able to find those. As you can see from the image, I have both the full drive and some subfolders connected. At the root, you have access to all the folders....but sometimes it is more convenient to connect directly tot he folder (e.g. c:\Student )
In ArcMap, the Scratch Workspace and Current Workspace environments are synchronized by default to the map document's default geodatabase.
In ArcCatalog, the Scratch Workspace and Current Workspace environments are not set by default.
I hope this helps!!!
Thanks Jayant. I tried your suggestion but I still cannot see this database. I am new to this so maybe it's hiding in plain sight.
You could check and modify the path of scratch workspace from GeoProcessing > Environment (Settings) > Workspace > Scratch Workspace
Using the current and scratch workspace environments—Help | ArcGIS for Desktop
