Glad I could help. 🙂One more thing about the data frame. If you move it entirely off of the page in the layout it won't be included in the exported emf, so you won't have to have any data in it to get rid of the "label". 🙂 The reason that works is it exports the page extent regardless of what's visible if you have the option "Clip to Graphics Extent" unchecked. If you have that option checked it exports everything that is visible, whether it's inside or outside the page.
I think it used to be you could tell Illustrator to export the entire artboard (but I could be mis-remembering). The option to Use Artboards is not enabled when exporting to emf (and some other formats) in AI6.You might try bringing your emf into an Arcmap layout with no other elements - there will be a data frame which you can't remove, so make sure its frame is set to none so it's not visible. And set the page size to what you want to finished emf's size to be. Position your emf so it's centered the way you want. Then export that "map" to emf from ArcMap, and make sure you have Clip Output to Graphics Extent turned off.
